メインコンテンツにスキップ
Craig Electronics CMP773 Screen Replacement
必要な工具と部品
  1. Craig Electronics CMP773 Screen Replacement, Screen: 手順 1、 2の画像 1 Craig Electronics CMP773 Screen Replacement, Screen: 手順 1、 2の画像 2
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: 手順 2、 3の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 2、 3の画像 2 Craig Electronics CMP773 Screen Replacement: 手順 2、 3の画像 3
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: 手順 3、 2の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 3、 2の画像 2
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: 手順 4、 2の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 4、 2の画像 2
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: 手順 5、 3の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 5、 3の画像 2 Craig Electronics CMP773 Screen Replacement: 手順 5、 3の画像 3
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: 手順 6、 3の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 6、 3の画像 2 Craig Electronics CMP773 Screen Replacement: 手順 6、 3の画像 3
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: 手順 7、 2の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 7、 2の画像 2
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: 手順 8、 1の画像 1
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: 手順 9、 1の画像 1
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: 手順 10、 2の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 10、 2の画像 2
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: 手順 11、 3の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 11、 3の画像 2 Craig Electronics CMP773 Screen Replacement: 手順 11、 3の画像 3
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: 手順 12、 3の画像 1 Craig Electronics CMP773 Screen Replacement: 手順 12、 3の画像 2 Craig Electronics CMP773 Screen Replacement: 手順 12、 3の画像 3
    • Grasp the exposed screen corner and gently separate the screen from the housing.
終わりに
作成者
4人の作成者と共同で作成されました。
Justin mersch
メンバー登録日: 11/07/19
205 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S3-G4, Harley Fall 2019 IUPUI, Team S3-G4, Harley Fall 2019人のメンバー
IUPUI-HARLEY-F19S3G4
4 メンバー
3のガイドは作成済み
コメント 1 件
What kind of battery does this device specifically use
Kris Miller - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 206
