メインコンテンツにスキップ
Craig CMP801 Front and Rear Facing Camera Replacement
必要な工具と部品
  1. Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: 手順 1、 2の画像 1 Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: 手順 1、 2の画像 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Front and Rear Facing Camera Replacement: 手順 2、 2の画像 1 Craig CMP801 Front and Rear Facing Camera Replacement: 手順 2、 2の画像 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Front and Rear Facing Camera Replacement: 手順 3、 2の画像 1 Craig CMP801 Front and Rear Facing Camera Replacement: 手順 3、 2の画像 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 手順 4、 2の画像 1 Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 手順 4、 2の画像 2
    • Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
  5. Craig CMP801 Front and Rear Facing Camera Replacement: 手順 5、 1の画像 1
    • Near the edge of the device, lift up the tab connected to the front-facing camera.
  6. Craig CMP801 Front and Rear Facing Camera Replacement: 手順 6、 2の画像 1 Craig CMP801 Front and Rear Facing Camera Replacement: 手順 6、 2の画像 2
    • Locate the black flap that covers and holds down the tab connected to the rear-facing camera.
    • Flip the flap up to release the tab.
  7. Craig CMP801 Front and Rear Facing Camera Replacement: 手順 7、 2の画像 1 Craig CMP801 Front and Rear Facing Camera Replacement: 手順 7、 2の画像 2
    • Gently pull on the tab connected to the front-facing camera to release both the front and rear-facing cameras.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Erin
メンバー登録日: 09/25/17
117 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G2, Thompson Fall 2017 University of North Texas, Team S2-G2, Thompson Fall 2017人のメンバー
UNT-THOMPSON-F17S2G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 262
