はじめに
This guide will walk you through the process of replacing the broken front or rear facing camera of a Craig CMP801.
必要な工具と部品
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
