メインコンテンツにスキップ
Craftsman Model 315.10721 Cord Replacement
必要な工具と部品
  1. Craftsman Model 315.10721 Cord Replacement, Cord: 手順 1、 1の画像 1
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
    • Each screw has a corresponding nut on the opposite side of the power saw
  2. Craftsman Model 315.10721 Cord Replacement: 手順 2、 1の画像 1
    • Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
  3. Craftsman Model 315.10721 Cord Replacement: 手順 3、 2の画像 1 Craftsman Model 315.10721 Cord Replacement: 手順 3、 2の画像 2
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the power cord are plugged in.
    • Release both the black and white wires and gently pull them from the leads.
    • To install the new cord, insert the wires of the new cord in the same way that they were removed.
終わりに
作成者
4人の作成者と共同で作成されました。
Riley Hilliker
メンバー登録日: 10/14/14
557 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 4-47, Amido Fall 2014 Cal Poly, Team 4-47, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S4G47
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 512
