メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
This guide is not for any specific repair, rather it is for cracking the device open in order to diagnose and treat your its inefficiencies.
パーツ
パーツは指定されていません。
  1. Turn the device upside down so that the three rubber pads are facing up.
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Use a heat gun (set to low) to apply heat  to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. Remove the heated rubber pad with a plastic opening tool.
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  5. Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver. Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  6. Open the device along its seam. Be careful when separating the device because there are wires connecting the two seperate halves. Be careful when separating the device because there are wires connecting the two seperate halves.
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  7. Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  8. Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device. Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
終わりに
Jared Everingham
メンバー登録日: 2014年01月23日
338 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G28
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 95
