パーツ
パーツは必要ありません。
  1. Slide the switch on the bottom of the laptop until the battery pops out. Once the battery pops out, you can remove it. Once the battery pops out, you can remove it.
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Using forceps or tweezers, remove  the two rear rubber feet to expose two hidden screws. Using forceps or tweezers, remove  the two rear rubber feet to expose two hidden screws.
    • Using forceps or tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Using a Phillips head #00 Screwdriver, remove a total of 12 screws: 10 screws in the battery compartment. size ph#00, approximately 3 mm long
    • Using a Phillips head #00 Screwdriver, remove a total of 12 screws:
      • 10 screws in the battery compartment.
        • size ph#00, approximately 3 mm long
      • 2 screws under the rubber feet previously removed
        • Size ph#00, approximately 4.5 mm long
  5. Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop. The case is easier to remove when separating in a clockwise motion, as seen in the pictures. The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  6. Once you've removed the lower case, you should see the Wi-Fi card on the corner of the device containing the USB port. Disconnect the Wire connections on the Wi-Fi card using forceps or tweezers. Disconnect the Wire connections on the Wi-Fi card using forceps or tweezers.
    • Once you've removed the lower case, you should see the Wi-Fi card on the corner of the device containing the USB port.
    • Disconnect the Wire connections on the Wi-Fi card using forceps or tweezers.
  7. Remove Screw securing Wi-Fi card. Size ph#00, approximately 3 mm long. Once the screw is removed, the Wi-Fi card will pop up.
    • Remove Screw securing Wi-Fi card.
      • Size ph#00, approximately 3 mm long.
    • Once the screw is removed, the Wi-Fi card will pop up.
    • Pull the Wi-Fi card to remove it from the device.
まとめ
Robert McLaughlin
メンバー登録日: 2014年09月09日
422 ポイント
3のガイドは作成済み
チーム
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S2G2
3 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 547
