メインコンテンツにスキップ
Cr-48 Chromebook SSD Replacement
必要な工具と部品
  1. Cr-48 Chromebook SSD Replacement, Battery: 手順 1、 3の画像 1 Cr-48 Chromebook SSD Replacement, Battery: 手順 1、 3の画像 2 Cr-48 Chromebook SSD Replacement, Battery: 手順 1、 3の画像 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: 手順 2、 2の画像 1 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: 手順 2、 2の画像 2
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: 手順 3、 3の画像 1 Cr-48 Chromebook SSD Replacement, Remove Screws: 手順 3、 3の画像 2 Cr-48 Chromebook SSD Replacement, Remove Screws: 手順 3、 3の画像 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook SSD Replacement: 手順 4、 3の画像 1 Cr-48 Chromebook SSD Replacement: 手順 4、 3の画像 2 Cr-48 Chromebook SSD Replacement: 手順 4、 3の画像 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: 手順 5、 3の画像 1 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: 手順 5、 3の画像 2 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: 手順 5、 3の画像 3
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: 手順 6、 2の画像 1 Cr-48 Chromebook SSD Replacement, Remove SSD: 手順 6、 2の画像 2
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
終わりに
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Athar
メンバー登録日: 09/09/14
365 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S2G2
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 23
過去 30 日: 68
今までの合計 3,041
