はじめに
Before starting, please:
- make sure nothing is attached (such as AC adapter, USB, VGA, audio jack).
- remove any inserted SD card.
必要な工具と部品
To take out the battery, slide the switch on the bottom of the laptop.
The battery should then pop out and you can remove it.
この手順で使用する道具:Tweezers$4.99
Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
Remove one black screw on the SSD using a PH #00 screwdriver.
Size ph#00, approximately 3 mm long.
5 の人々がこのガイドを完成させました。
