ツール
パーツ
パーツは指定されていません。
Slide the switch on the bottom of the laptop until the battery pops out.
Once the battery pops out, you can remove it.
Using forceps or tweezers, remove the two rear rubber feet to expose two hidden screws.
Using a Phillips head #00 Screwdriver, remove a total of 12 screws:
10 screws in the battery compartment.
size ph#00, approximately 3 mm long
2 screws under the rubber feet previously removed
Size ph#00, approximately 4.5 mm long
Locate the RAM under a black flap alongside where the laptop screen and device body meet.
Locate the metal clasps on either side of the RAM Card
Using your thumbs, pull the pieces away from the RAM and then the RAM card should pop up.
2 の人々がこのガイドを完成させました。
