メインコンテンツにスキップ
はじめに
The Cr-48 Chromebook shipped with a combined Wi-Fi / Cellular network card that can be easily removed and replaced if necessary. Use this guide to replace a malfunctioning network card in a Cr-48 Chromebook.
パーツ
パーツは指定されていません。
  1. Cr-48 Chromebook Network Card Replacement, Remove the Battery: 手順 1、 3の画像 1 Cr-48 Chromebook Network Card Replacement, Remove the Battery: 手順 1、 3の画像 2 Cr-48 Chromebook Network Card Replacement, Remove the Battery: 手順 1、 3の画像 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook Network Card Replacement, Remove Rear Rubber Feet: 手順 2、 2の画像 1 Cr-48 Chromebook Network Card Replacement, Remove Rear Rubber Feet: 手順 2、 2の画像 2
    • Using forceps or tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook Network Card Replacement, Remove Screws: 手順 3、 3の画像 1 Cr-48 Chromebook Network Card Replacement, Remove Screws: 手順 3、 3の画像 2 Cr-48 Chromebook Network Card Replacement, Remove Screws: 手順 3、 3の画像 3
    • Using a Phillips head #00 Screwdriver, remove a total of 12 screws:
    • 10 screws in the battery compartment. Size ph#00, approximately 3 mm long.
    • 2 screws under rubber feet. Size ph#00, approximately 4.5 mm long.
  4. Cr-48 Chromebook Network Card Replacement: 手順 4、 3の画像 1 Cr-48 Chromebook Network Card Replacement: 手順 4、 3の画像 2 Cr-48 Chromebook Network Card Replacement: 手順 4、 3の画像 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 手順 5、 3の画像 1 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 手順 5、 3の画像 2 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: 手順 5、 3の画像 3
    • Once you've removed the lower case, you should see the network card on the corner of the device containing the USB port.
    • Disconnect the Wire connections on the network card using forceps or tweezers.
  6. Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 手順 6、 3の画像 1 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 手順 6、 3の画像 2 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: 手順 6、 3の画像 3
    • Remove Screw securing network card.
    • Size ph#00, approximately 3 mm long.
    • Once the screw is removed, the network card will pop up.
    • Pull the network card to remove it from the device.
終わりに
Robert McLaughlin
メンバー登録日: 2014年09月09日
462 ポイント
3のガイドは作成済み
チーム
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014人のメンバー
CSUF-BRUCE-F14S2G2
3 メンバー
10のガイドは作成済み
コメント1件
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
Jorge Gomes - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 828
