メインコンテンツにスキップ
Cowon iAudio U2 Headphone Jack Replacement
必要な工具と部品
  1. Cowon iAudio U2 Headphone Jack Replacement, Headphone Jack: 手順 1、 1の画像 1
    • Before starting the disassembly, make sure the device is powered off.
    • Unscrew the 4 screws using the PH000 drill bit from the iFixit toolkit.
    • Don't forget to store the screws in a safe location, such as a magnetic board. You will need the screws to put the device back together later.
  2. Cowon iAudio U2 Headphone Jack Replacement: 手順 2、 2の画像 1 Cowon iAudio U2 Headphone Jack Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool from the iFixit toolkit to separate the back from the front of the device. To do this, wedge the opening tool into the crack where the two sides of the device cover meet.
    • After the tool is wedged in, push down on the exposed end until the two sides come apart.
  3. Cowon iAudio U2 Headphone Jack Replacement: 手順 3、 1の画像 1
    • Using the PH000 drill bit from the iFixit toolkit, unscrew the 2 screws that attach the motherboard to the device.
  4. Cowon iAudio U2 Headphone Jack Replacement: 手順 4、 1の画像 1
    • Using the plastic opening tool from the iFixit toolkit, insert the tool in between the device and the motherboard. Push down on the exposed end of the device to release the motherboard from the device.
  5. Cowon iAudio U2 Headphone Jack Replacement: 手順 5、 2の画像 1 Cowon iAudio U2 Headphone Jack Replacement: 手順 5、 2の画像 2
    • Using the soldering tool, remove the headphone jack from the device.
    • Be careful when using the soldering device as it will be very hot.
    • Using the soldering tool, replace the old headphone jack with a new one. Solder the new headphone jack into place.
終わりに
作成者
4人の作成者と共同で作成されました。
Justin Proshka
メンバー登録日: 01/14/16
624 ポイント
5のガイドは作成済み
チーム
USF Sarasota-Manatee, Team 1-2, Stewart Spring 2016 USF Sarasota-Manatee, Team 1-2, Stewart Spring 2016人のメンバー
USFSM-STEWART-S16S1G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 407
