メインコンテンツにスキップ
Corsair Void Pro RGB Volume Switch Replacement
必要な工具と部品
  1. Corsair Void Pro RGB Volume Switch Replacement, Earcup: 手順 1、 1の画像 1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Volume Switch Replacement: 手順 2、 2の画像 1 Corsair Void Pro RGB Volume Switch Replacement: 手順 2、 2の画像 2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Volume Switch Replacement: 手順 3、 2の画像 1 Corsair Void Pro RGB Volume Switch Replacement: 手順 3、 2の画像 2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Volume Switch Replacement, Volume Switch: 手順 4、 1の画像 1
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
  5. Corsair Void Pro RGB Volume Switch Replacement: 手順 5、 1の画像 1
    • Pull the volume switch out and remove it from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Gianna Nobili
メンバー登録日: 04/15/19
827 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S9-G13, Maness Spring 2019 Cal Poly, Team S9-G13, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S9G13
4 メンバー
14のガイドは作成済み
コメント 1 件
Heads up, some headsets have hot glue holding the wiring down below the speakers, and sometimes the hot glue will grab the speaker frame so its impossible to teardown the headset without damaging the wires, speaker or PCB board.
Found this out when my volume wheel was catching on something, so i decided to check it out. It was a glob of glue in the way of the wheel making it difficult to hit the switch to adjust the volume. Took me a little creative thinking to remove it with a plastic pointer/ scraper, and some fine tweezers, as the speaker panel was being held down by a large glob of glue.
USB Lynx - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 43
今までの合計 2,760
