メインコンテンツにスキップ
Corsair Katar Scroll Wheel Sensor
必要な工具と部品
  1. Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: 手順 1、 2の画像 1 Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: 手順 1、 2の画像 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Scroll Wheel Sensor: 手順 2、 1の画像 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Scroll Wheel Sensor: 手順 3、 2の画像 1 Corsair Katar Scroll Wheel Sensor: 手順 3、 2の画像 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Scroll Wheel Sensor: 手順 4、 1の画像 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar Scroll Wheel Sensor, Scroll Wheel: 手順 5、 2の画像 1 Corsair Katar Scroll Wheel Sensor, Scroll Wheel: 手順 5、 2の画像 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar Scroll Wheel Sensor: 手順 6、 1の画像 1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar Scroll Wheel Sensor: 手順 7、 1の画像 1
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
  8. Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: 手順 8、 2の画像 1 Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: 手順 8、 2の画像 2
    • Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
  9. Corsair Katar Scroll Wheel Sensor: 手順 9、 2の画像 1 Corsair Katar Scroll Wheel Sensor: 手順 9、 2の画像 2
    • Desolder the 5 connecting pins to remove the scroll wheel sensor from the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Margaret Loughren
メンバー登録日: 07/12/18
594 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018人のメンバー
UWT-CARDINAL-SU18S1G3
3 メンバー
12のガイドは作成済み
2 件のコメント
bonsoir moi ma molette tourne dans le vide rien ne accroche merci
Tara - 返信
Do I need new pads when I take out the old ones or will the same one stick?
Ishaan Patel - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 25
今までの合計 1,521
