メインコンテンツにスキップ
Coolpad Defiant Rear Camera Replacement
必要な工具と部品
  1. Coolpad Defiant Rear Camera Replacement, Back Cover: 手順 1、 2の画像 1 Coolpad Defiant Rear Camera Replacement, Back Cover: 手順 1、 2の画像 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Rear Camera Replacement: 手順 2、 1の画像 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Rear Camera Replacement, Battery: 手順 3、 1の画像 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Rear Camera Replacement, Rear Camera: 手順 4、 1の画像 1
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
  5. Coolpad Defiant Rear Camera Replacement: 手順 5、 2の画像 1 Coolpad Defiant Rear Camera Replacement: 手順 5、 2の画像 2
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
  6. Coolpad Defiant Rear Camera Replacement: 手順 6、 1の画像 1
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
  7. Coolpad Defiant Rear Camera Replacement: 手順 7、 3の画像 1 Coolpad Defiant Rear Camera Replacement: 手順 7、 3の画像 2 Coolpad Defiant Rear Camera Replacement: 手順 7、 3の画像 3
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
  8. Coolpad Defiant Rear Camera Replacement: 手順 8、 3の画像 1 Coolpad Defiant Rear Camera Replacement: 手順 8、 3の画像 2 Coolpad Defiant Rear Camera Replacement: 手順 8、 3の画像 3
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
  9. Coolpad Defiant Rear Camera Replacement: 手順 9、 1の画像 1
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
終わりに
作成者
2人の作成者と共同で作成されました。
Johnny Boland
メンバー登録日: 09/21/18
500 ポイント
3のガイドは作成済み
チーム
University of North Texas, Team S5-G6, Thompson Fall 2018 University of North Texas, Team S5-G6, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S5G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 257
