Turn the phone with the back cover facing towards you.
Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
The plastic case and inner components can break if not pulled carefully, so pull cautiously.
Find the gap on the bottom of the battery.
With a tool or with your hands, pull the battery upward and set it aside safely.
Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
Be careful with old or damaged batteries and dispose of it appropriately
Disconnect the metal cable using the plastic spudger.
The remove the glued down speaker from the backing.
Disconnect the little black wire from lower logic board.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
