メインコンテンツにスキップ
Coolpad Defiant Daughterboard Replacement
必要な工具と部品
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: 手順 1、 2の画像 1 Coolpad Defiant Daughterboard Replacement, Back Cover: 手順 1、 2の画像 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: 手順 2、 1の画像 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: 手順 3、 1の画像 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: 手順 4、 2の画像 1 Coolpad Defiant Daughterboard Replacement, Daughterboard: 手順 4、 2の画像 2
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: 手順 5、 3の画像 1 Coolpad Defiant Daughterboard Replacement: 手順 5、 3の画像 2 Coolpad Defiant Daughterboard Replacement: 手順 5、 3の画像 3
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: 手順 6、 1の画像 1
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
終わりに
作成者
1人の作成者と共同作成されました。
Elijah Gastin
メンバー登録日: 09/21/18
100 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S5-G6, Thompson Fall 2018 University of North Texas, Team S5-G6, Thompson Fall 2018人のメンバー
UNT-THOMPSON-F18S5G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 474
