はじめに
Capacitors are electronic components found in almost every device containing a circuit board. Large capacitors can store enough charge to cause injuries, so they must be discharged properly.
This guide will show you how to make a simple resistor-based capacitor discharge tool.
必要な工具と部品
To construct a capacitor discharge tool, first gather the necessary materials. These include:
Two lengths of wire. Minimum wire requirements is 12AWG, 600 volt rating for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry
A resistor rated to dissipate the amount of thermal energy created when discharging the capacitor. Minimum requirements for resistor is 2k OHM 5w for small capacitors, 20k OHM 5w for large electrolytic capacitors used in power supplies, electric motor start circuits and camera flash circuitry.
Shrink tubing
135 の人々がこのガイドを完成させました。
11 件のコメント
thank you !!! :)
This article is by far the best I've read. I have made these in the past and had to get past the amount of words used to describe what needed to be done with what. This article is straight to the point and the tips ( using alligator clip ) are excellent.
I get the basics and can build something more to fit my needs, with what you have instructed
puckhead22 - 返信
hi
i have one query, if it is possible to discharge the capacitor in 12V 1 A power supply..? if i cut of the power, the power supply discharge the power around 6 sec but i need to discharge it with in 1 sec ..? this is possible or Not...?
Thank you! I have been looking for a good diy discharge probe....I also used overlapping large size heat shrink to strengthen the joint at the ceramic resistor to prevent failure at a bad time.
doorabull2 - 返信
Great. Now how do I use it?!?!
Rex Kramer - 返信
i believe all you need to do is by bridging every lead with your built capacitor discharge. I could be wrong tho
just want to say thank you for great explanation! Terima kasih, from Indonesia
I thought of adding an LED to the circuit. it'll show u that it's discharged when the light dies off.
It's a good idea but it is safer to rely on the voltage measurement of a quality multimeter than on an indicator LED. Though the LED is off, you can’t be sure whether the capacitor is actually discharged or if something is wrong with the LED or its circuit.
Think a lead light can be added, or else how would one know.
