メインコンテンツにスキップ
Connecting to WiFi with your Kindle Fire HDX 7"
  1. Connecting to WiFi with your Kindle Fire HDX 7", Opening the Quick Settings Menu: 手順 1、 1の画像 1
    • Turn your device on and wait for the home screen to load.
    • Once you are at the home screen, use your finger and swipe down from the top of the LCD Screen to bring up the Quick Settings menu.
  2. Connecting to WiFi with your Kindle Fire HDX 7", Adding a wireless network: 手順 2、 1の画像 1
    • While in the Quick Settings menu, tap "Wireless".
    • Please note that your device will not connect to a WiFi network if your device is in "Airplane Mode", make sure Airplane Mode is set to Off.
  3. Connecting to WiFi with your Kindle Fire HDX 7": 手順 3、 1の画像 1
    • Tap the "WiFi" button, which will bring up a list of networks that are in range.
    • Tap a WiFi network, then press "Connect" in order to connect to it.
    • If you see a lock on the network, you may need a password in order for you to gain access to the network. Enter the password then press "Connect".
    • If you don't know the password for the network you are trying to connect to, try contacting the person who set up the network.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Connor Michienzie
メンバー登録日: 10/16/14
161 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 1-2, Duarte Fall 2014 UMass Dartmouth, Team 1-2, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S1G2
4 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 648
