メインコンテンツにスキップ
Connecting Cables to the Motherboard
必要な工具と部品
  1. Connecting Cables to the Motherboard, Connecting Cables to the Motherboard: 手順 1、 2の画像 1 Connecting Cables to the Motherboard, Connecting Cables to the Motherboard: 手順 1、 2の画像 2
    • Red- Optional ATX Connector
    • Orange- CPU Fan 1
    • Yellow- CPU Fan 2
    • Green- Main ATX Connectors
    • Light Blue- GPU
    • Blue- Panel Connectors
    • Pink- USB Connectors
    • Black- HD Audio
  2. Connecting Cables to the Motherboard, Optional ATX Connector: 手順 2、 2の画像 1 Connecting Cables to the Motherboard, Optional ATX Connector: 手順 2、 2の画像 2
    • Connect the two separate six-pin segments to six pins each on the 12-pin PCIE port.
  3. Connecting Cables to the Motherboard, CPU Fan 1: 手順 3、 2の画像 1 Connecting Cables to the Motherboard, CPU Fan 1: 手順 3、 2の画像 2
    • Connect the four pin segment to the four pin PCEI connector labeled "CPUFAN1."
  4. Connecting Cables to the Motherboard, CPU Fan 2: 手順 4、 2の画像 1 Connecting Cables to the Motherboard, CPU Fan 2: 手順 4、 2の画像 2
    • Connect the four pin segment to the four pin PCIE port labeled "CPUFAN2."
  5. Connecting Cables to the Motherboard, Main ATX Connector: 手順 5、 2の画像 1 Connecting Cables to the Motherboard, Main ATX Connector: 手順 5、 2の画像 2
    • Connect the 24 pin segment to the 24 pin PCIE port.
  6. Connecting Cables to the Motherboard, GPU: 手順 6、 2の画像 1 Connecting Cables to the Motherboard, GPU: 手順 6、 2の画像 2
    • Connect both of the separate eight pin segments to each of the eight pin PCIE ports on the graphics card.
  7. Connecting Cables to the Motherboard, Panel Connectors (Part 1): 手順 7、 3の画像 1 Connecting Cables to the Motherboard, Panel Connectors (Part 1): 手順 7、 3の画像 2 Connecting Cables to the Motherboard, Panel Connectors (Part 1): 手順 7、 3の画像 3
    • This PCIE port consists of eight pins, two rows of four.
    • Connect the "Power LED+" pin to the pin at the top right corner.
    • Connect the "Power LED-" segment to the pin next to the "Power LED+" segment in the top row.
    • Connect the "Power SW" segment to the two pins on the left side of the top row of pins.
  8. Connecting Cables to the Motherboard, Panel Connectors (Part 2): 手順 8、 3の画像 1 Connecting Cables to the Motherboard, Panel Connectors (Part 2): 手順 8、 3の画像 2 Connecting Cables to the Motherboard, Panel Connectors (Part 2): 手順 8、 3の画像 3
    • Connect the "HDD LED" segment to the two pins on the right side of the bottom row of pins.
    • Connect the "Reset SW" segment to the two pins on the left side of the bottom row of pins.
  9. Connecting Cables to the Motherboard, USB Connector: 手順 9、 2の画像 1 Connecting Cables to the Motherboard, USB Connector: 手順 9、 2の画像 2
    • Connect the nine pin segment to the nine pin PCIE port.
  10. Connecting Cables to the Motherboard, HD Audio: 手順 10、 2の画像 1 Connecting Cables to the Motherboard, HD Audio: 手順 10、 2の画像 2
終わりに
To disconnect the cable ties, follow these directions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Grace Parsekian
メンバー登録日: 12/05/23
241 ポイント
1ガイドが承認済み
1件のガイドコメント
Rest comment brancher un processeur. Merci comme-me.
Kader Lahcene - 返信
コメントを追加
統計データ:
過去 24時間: 55
過去 7 日: 331
過去 30 日: 1,441
今までの合計 19,686
