メインコンテンツにスキップ
Connect Four Electronic Handheld Speaker Replacement
必要な工具と部品
  1. Connect Four Electronic Handheld Speaker Replacement, Ensure the device is off.: 手順 1、 1の画像 1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: 手順 2、 2の画像 1 Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: 手順 2、 2の画像 2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: 手順 3、 2の画像 1 Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: 手順 3、 2の画像 2
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
  4. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 手順 4、 3の画像 1 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 手順 4、 3の画像 2 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 手順 4、 3の画像 3
    • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
    • Locate the speaker on the back casing.
    • Using a spudger, wedge the speaker out of its place until it slides out.
    • Take the replacement speaker and wedge it back into its space.
  5. Connect Four Electronic Handheld Speaker Replacement, Re-Soldering the Speaker Wire: 手順 5、 1の画像 1
    • Using a soldering iron, solder both red wires to their appropriate connections.
    • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Wil
メンバー登録日: 10/22/14
313 ポイント
3のガイドは作成済み
チーム
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G11
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 9
今までの合計 368
