メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement
必要な工具と部品
    1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Back Panel: 手順 1、 1の画像 1
      • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
      • Hold the hair dryer by the handle so that the back panel faces up.
      FixBotに聞いてみる
      コメントを追加
    2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 2、 2の画像 1 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 2、 2の画像 2
      • Remove the two 15.875 mm Phillips #2 screws from the back panel.
      FixBotに聞いてみる
      コメントを追加
    3. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 3、 3の画像 1 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 3、 3の画像 2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 3、 3の画像 3
      • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
      • Continue separating the back panel, working along the seam.
      • With moderate force, completely remove the back panel from the hair dryer.
      FixBotに聞いてみる
      コメントを追加
    1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: 手順 4、 2の画像 1 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: 手順 4、 2の画像 2
      • Hold the hair dryer by the nozzle so that the handle points to the left.
      • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
      FixBotに聞いてみる
      コメントを追加
    2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 5、 3の画像 1 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 5、 3の画像 2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: 手順 5、 3の画像 3
      • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
      • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
      • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Timothy Lo
メンバー登録日: 04/22/14
1,214 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S10G58
4 メンバー
28のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 48
今までの合計 8,597
