はじめに
If you are having trouble with your cord retracting then here are a few simple steps to replacing it. The only tool you will need is a Phillips screwdriver. You will also need a new retracting wheel to replace with the old one at the end.
必要な工具と部品
Remove the inner white disk piece by gently pulling it out with your finger nail.
ある他の人がこのガイドを完成しました。
コメント 1 件
Nicely done, just a suggestion, in Step #10 would suggest using fingers or flat object on top of spring when disengaging from frame …to ensure it won’t unravel and jump (as shown in 2nd picture + have some strong tape, string, wire ties, etc. to keep the spring wound up. This works for me when dealing with lawn mower recoil mechanism or tape measures. Tape measures are the worst to work on. lol - AHNauss
