メインコンテンツにスキップ
この分解で使用される工具
この分解は修理ガイドでは ありません。 お持ちのMacintosh Color Classicを修理する際は、iFixitの修理ガイドをご利用ください。
  1. My Macintosh Color Classic running under MacOS 7.6 some days before it died
    • My Macintosh Color Classic running under MacOS 7.6 some days before it died
  2. Machine completely emptied
    • Machine completely emptied
  3. all original components…
    • all original components…
  4. ...were replaced with the new ones
    • ...were replaced with the new ones
  5. Testing the new HDMI 8” LCD screen.
    • Testing the new HDMI 8” LCD screen.
  6. The chassis and the power supply board were cleaned up and adapted for fitting the new components.
    • The chassis and the power supply board were cleaned up and adapted for fitting the new components.
  7. Installing the new screen
    • Installing the new screen
  8. Closing the back case
    • Closing the back case
  9. Sliding in and connecting the MacMini 2014
    • Sliding in and connecting the MacMini 2014
  10. Closing the clip-in backplane
    • Closing the clip-in backplane
  11. Plugging in the computer
    • Plugging in the computer
  12. Starting the computer
    • Starting the computer
  13. Macintosh Color Classic running under MacOS Mojave
    • Macintosh Color Classic running under MacOS Mojave
  14. Insert wisdom here. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
Roberto
メンバー登録日: 2017年06月08日
245 ポイント
1ガイドが承認済み
8 件のコメント
Wow, such a clean built. Thanks for sharing!
Luke - 返信
La pantalla es lo que mas temor da retirar si es igual a las de la emac y imacs, me gustaría haberlo hecho con la que me dañaron en un taller, no la guarde y tire la basura, en fin jamas se sabe lo que la tecnología nueva nos permite hacer con las viejas carcazas, debe ser grato ver la cara de la gente que te ve trabajar en ella con teclado y ratón inalámbricos.
javiersconde - 返信
Do you have a more detailed breakdown, including exact parts used. I have one of these Macs and it has died. The sentimental value is huge so doing to it what you did to yours is an awesome idea. Thanks
Nathan Fletcher - 返信
Sorry, I haven’t more details of the breakdown. The most difficult part was to clean up the power supply board and to saw parts of the plastic chassis to fit the MacMini inside. The parts I kept from the original machine are the chassis, the power supply board and the framework that sustained the original screen.
Roberto -
Roberto, what size is the fan? 60x25mm? And can you remove the stock fan from that metal housing so as to replace it with a quieter modern version? Thanks.
James Wages - 返信
I am guessing it is 80x25mm and runs at 12V, but is it 2-wire or 3-wire?
I ask in order to know what kind of replacement to buy. Thanks!
James Wages -
Hi James, the fan is 80x80x25, 2-wire and can be removed from the metal housing.
Roberto -
I have added some pictures of the fan.
Roberto -
コメントを追加
統計データを表示:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 30
今までの合計 2,725
