はじめに
Without a keyboard the computer becomes essentially unusable. In this guide, you will learn how to remove and replace the keyboard.
必要な工具と部品
Shutdown the computer.
Remove all external devices.
Unplug the power, and any other cords, from the laptop.
Turn the laptop upside down, with the front towards you.
On the optical drive there is small pin hole. Insert a paperclip or similarly sized object in the hole.
The Drive will pop a short way out of the computer.
Remove the two 4mm Philips #1 screws that secure the switch cover to the computer.
Turn the computer display-side up with the front panel toward you.
Open the computer display as far as possible.
Insert a plastic opening tool into the slots located behind the [F5] key and lift the front edge of the switch cover until it disengages from the computer.
Insert a plastic opening tool into the slots located behind the [Insert] key and lift the front edge of the switch cover until it disengages from the computer.
Remove the switch cover.
