メインコンテンツにスキップ
Compaq Presario V2414NR Hard Drive Replacement
必要な工具と部品
  1. Compaq Presario V2414NR Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR Hard Drive Replacement: 手順 2、 2の画像 1 Compaq Presario V2414NR Hard Drive Replacement: 手順 2、 2の画像 2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR Hard Drive Replacement, Hard Drive: 手順 3、 2の画像 1 Compaq Presario V2414NR Hard Drive Replacement, Hard Drive: 手順 3、 2の画像 2
    • Loosen the two 5mm Philips #1 screws that secure the hard drive cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the left side of the cover and swing it to the right to remove it.
  4. Compaq Presario V2414NR Hard Drive Replacement: 手順 4、 2の画像 1 Compaq Presario V2414NR Hard Drive Replacement: 手順 4、 2の画像 2
    • Grasp the black Mylar tab on the hard drive frame and pull firmly straight up until the hard drive disconnects from the computer, and remove it.
    • When reassembling: First, align the two tabs on the hard drive with the slots in the chassis, then press down on the left edge of the hard drive to seat the contacts.
  5. Compaq Presario V2414NR Hard Drive Replacement: 手順 5、 2の画像 1 Compaq Presario V2414NR Hard Drive Replacement: 手順 5、 2の画像 2
    • Remove the four 4mm Philips #1 screws, two on each side, that secure the hard drive frame to the hard drive.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to remove if from the hard drive.
  6. Compaq Presario V2414NR Hard Drive Replacement: 手順 6、 1の画像 1
    • Slide the hard drive connector straight off of the hard drive.
    • Be sure not to tilt the connector while removing it to avoid bending the delicate hard drive connector pins.
    • When reassembling, position the contacts towards the top of the drive (metal covered side).
終わりに
作成者
3人の作成者と共同で作成されました。
Rylie Schmidt
メンバー登録日: 04/19/15
765 ポイント
7のガイドは作成済み
チーム
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 UMass Dartmouth, Team 2-1, Isaacson Fall 2016人のメンバー
UMASSD-ISAACSON-F16S2G1
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 728
