メインコンテンツにスキップ
Compaq Presario CQ62-215dx CPU Replacement
必要な工具と部品
  1. Compaq Presario CQ62-215dx CPU Replacement, CPU: 手順 1、 1の画像 1
    • Turn the laptop upside down.
    • Remove all the 3.0mm Phillips #00 screws from the back cover.
  2. Compaq Presario CQ62-215dx CPU Replacement: 手順 2、 1の画像 1
    • Remove the battery, RAM, and hard drive.
  3. Compaq Presario CQ62-215dx CPU Replacement: 手順 3、 1の画像 1
    • Remove four 1.2mm Phillips #00 screws under the battery.
  4. Compaq Presario CQ62-215dx CPU Replacement: 手順 4、 1の画像 1
    • Turn the laptop over, and open the laptop cover.
    • Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx CPU Replacement: 手順 5、 1の画像 1
    • Use a spudger or your hand to lift the outside frame from the corner of the laptop.
  6. Compaq Presario CQ62-215dx CPU Replacement: 手順 6、 1の画像 1
    • Remove all the 1.2mm Phillips #00 screws from the motherboard and in the top corner that secures the fan.
  7. Compaq Presario CQ62-215dx CPU Replacement: 手順 7、 1の画像 1
    • Unplug the wires connected to the motherboard with a spudger.
  8. Compaq Presario CQ62-215dx CPU Replacement: 手順 8、 1の画像 1
    • Remove the two 3mm Phillips #00 screws beside the fan.
  9. Compaq Presario CQ62-215dx CPU Replacement: 手順 9、 1の画像 1
    • Lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx CPU Replacement: 手順 10、 1の画像 1
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx CPU Replacement: 手順 11、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx CPU Replacement: 手順 12、 1の画像 1
    • Remove the fan from the motherboard.
    • When reassembling, you will need to solder the fan back on to the CPU.
  13. Compaq Presario CQ62-215dx CPU Replacement: 手順 13、 1の画像 1
    • Use the metal spudger to twist the lock tab on the component.
  14. Compaq Presario CQ62-215dx CPU Replacement: 手順 14、 1の画像 1
    • Remove current CPU and replace with new component.
終わりに
作成者
3人の作成者と共同で作成されました。
Breana Thibodeaux
メンバー登録日: 03/24/19
760 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 UMass Dartmouth, Team S4-G1, Valliere Spring 2019人のメンバー
UMASSD-VALLIERE-S19S4G1
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 19
今までの合計 1,299
