メインコンテンツにスキップ
Compaq Presario CQ62 Motherboard Replacement
必要な工具と部品
  1. Compaq Presario CQ62  Motherboard Replacement, Motherboard: 手順 1、 1の画像 1
    • Turn the computer over as shown in the image.
    • Remove the two M2.5x5 screws that secure the cover of the hard drive.
  2. Compaq Presario CQ62  Motherboard Replacement: 手順 2、 2の画像 1 Compaq Presario CQ62  Motherboard Replacement: 手順 2、 2の画像 2
    • Remove the hard drive by carefully pushing upwards on the metal supports.
    • When free, carefully release the hard drive's connector.
  3. Compaq Presario CQ62  Motherboard Replacement: 手順 3、 3の画像 1 Compaq Presario CQ62  Motherboard Replacement: 手順 3、 3の画像 2 Compaq Presario CQ62  Motherboard Replacement: 手順 3、 3の画像 3
    • Unscrew the two screws securing the lid for WLAN & RAM.
    • Remove the screw holding the WLAN module in place.
    • Release the two RF connectors on the WLAN module.
  4. Compaq Presario CQ62  Motherboard Replacement: 手順 4、 1の画像 1
    • Lift up on the WLAN module to forty-five degrees, and gently pull it out.
  5. Compaq Presario CQ62  Motherboard Replacement: 手順 5、 1の画像 1
    • Remove the thirteen bottom screws.
    • Remove the screws holding in the keyboard.
  6. Compaq Presario CQ62  Motherboard Replacement: 手順 6、 2の画像 1 Compaq Presario CQ62  Motherboard Replacement: 手順 6、 2の画像 2
    • To remove the keyboard, use the spudger to release the snaps between the casing and the keyboard top. Remove the snaps all the way around the device except around the LDC area.
    • Using a spudger, firmly press the keyboard from the function keys downward towards the bottom of the keyboard to remove the board.
  7. Compaq Presario CQ62  Motherboard Replacement: 手順 7、 3の画像 1 Compaq Presario CQ62  Motherboard Replacement: 手順 7、 3の画像 2 Compaq Presario CQ62  Motherboard Replacement: 手順 7、 3の画像 3
    • When pressing down on the keyboard, make sure to use enough force to overcome the adhesive.
    • When lifting out the keyboard be mindful of the keyboard's flex cables that need to be disconnected when the keyboard is loose.
    • Remove the flex cables by opening the connectors and removing them (there are 5 in total).
    • Remove the three screws.
    • Remove the top cover with a spudger.
終わりに
To reassemble your device, follow these instructions in reverse order. To dissasemble the logic board see the other ifixit guide for this laptop.
5 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Carsten Dahl Hjarup
メンバー登録日: 11/04/13
2,796 ポイント
8のガイドは作成済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 5,942
