はじめに
In this guide we are looking at the bottom side of the Compaq Persario. Please make sure your laptop is not connected to any power source and the battery is remove from the laptop. We are going to remove the cover of the hard drive and go through the process of replacing it.
必要な工具と部品
On the underside of the battery, there is lock that keeps the battery in place. Using your finger, slide the battery lock to unlock the battery. When you have unlocked it, just lift the battery to remove it.
ある他の人がこのガイドを完成しました。
