はじめに
You will need to assemble the proper tools shown in the first step of this guide before you continue forward.
This guide is meant to assist the reader with the proper steps to remove and replace the keyboard of the Compaq Evo N1000v device.
パーツ
パーツは必要ありません。
Carefully remove the screws located inside the red circles.
  • Carefully remove the screws located inside the red circles.
コメントを追加する
Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel. Push down on the spudger to lift the LED display panel upward.
  • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
  • Push down on the spudger to lift the LED display panel upward.
  • Do this on both the left and right sides of the device as shown in the images.
コメントを追加する
Completely remove the LED display panel from the device.
  • Completely remove the LED display panel from the device.
コメントを追加する
Left the keyboard up from the back end as shown in the image.
  • Left the keyboard up from the back end as shown in the image.
コメントを追加する
Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
  • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
コメントを追加する
Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
  • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
  • Repeat this action on the right side of the lock.
コメントを追加する
Pull the keyboard upward to remove it from the device.
  • Pull the keyboard upward to remove it from the device.
  • Repeat these steps in reverse order to install the new keyboard.
コメントを追加する
まとめ
ある他の人がこのガイドを完成しました。
ryan
メンバー登録日: 2014年03月12日
470 ポイント
4のガイドは作成済み
チーム
University of Maryland, Team 2-1, Vijaybhaskar Spring 2014 University of Maryland, Team 2-1, Vijaybhaskar Spring 2014人のメンバー
UMD-VIJAYBHASKAR-S14S2G1
3 メンバー
4のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 184
