メインコンテンツにスキップ
Compact Fluorescent Lightbulb CFL Lightbulb Replacement
  1. Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: 手順 1、 2の画像 1 Compact Fluorescent Lightbulb CFL Lightbulb Replacement, CFL Lightbulb: 手順 1、 2の画像 2
    • Locate the bad bulb and remove it from the socket. This is achieved by grabbing the bulb lightly and rotating counter-clockwise.
    • The bulb may be hot. If so, use gloves, or wait for it to cool.
  2. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: 手順 2、 1の画像 1
    • Procure a new lightbulb, either from a hardware store, or wherever it is you keep new ones.
    • Install the new lightbulb into the socket, this time rotating clockwise.
    • Be sure the power to the socket is turned off before you preform this step. Failure to do so my cause injury.
  3. Compact Fluorescent Lightbulb CFL Lightbulb Replacement: 手順 3、 1の画像 1
    • Turn the power on to the light socket by means of a switch or knob.
    • Congratulations! You have successfully changed a lightbulb! Reward your efforts by getting a cold beverage of your choice.
ゴール
12 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
WiseGeek
メンバー登録日: 04/04/11
1,364 ポイント
2のガイドは作成済み
コメント 1 件
You shouldn't unscrew/screw CFL Bulb from its tube because there is a very small risk that it will break (Especially if it has the tubular shape (2U, 3U and 4U)). Try to unscrew/screwing it from its plastic base.
Jokid - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 19
今までの合計 7,893
