メインコンテンツにスキップ
Commodore 64 Removing the Shift-Lock Key
必要な工具と部品
  1. Commodore 64 Removing the Shift-Lock Key, Removing the screws: 手順 1、 3の画像 1 Commodore 64 Removing the Shift-Lock Key, Removing the screws: 手順 1、 3の画像 2 Commodore 64 Removing the Shift-Lock Key, Removing the screws: 手順 1、 3の画像 3
    • 1. Remove three 6.75mm ph2 screw heads from the casing.
  2. Commodore 64 Removing the Shift-Lock Key, Opening the Case: 手順 2、 1の画像 1
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
  3. Commodore 64 Removing the Shift-Lock Key, Removing screws (continued): 手順 3、 1の画像 1
    • 3. Remove eight 6.75 mm ph2 screw heads to detach the keyboard face from the front casing. (Two remaining screws on the right side.)
  4. Commodore 64 Removing the Shift-Lock Key, Removing Screws (continued): 手順 4、 1の画像 1
    • 4. Remove twenty-three 3.38 mm ph2 screw heads from the back of the keyboard facing
  5. Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 手順 5、 3の画像 1 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 手順 5、 3の画像 2 Commodore 64 Removing the Shift-Lock Key, Removing the keyboard bundle cords from the motherboard: 手順 5、 3の画像 3
    • 5. Detach the multi-colored wire bundles connected to the motherboard
  6. Commodore 64 Removing the Shift-Lock Key, Cutting the Wires: 手順 6、 1の画像 1
    • 6. Next, carefully cut the two small wires which are connected from the Shift/Lock key to the keyboard.
  7. Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: 手順 7、 2の画像 1 Commodore 64 Removing the Shift-Lock Key, Removing the Shift-Lock key: 手順 7、 2の画像 2
    • 7. Turn the keyboard down on its face and push the shift lock key out from the back of the keyboard.
  8. Commodore 64 Removing the Shift-Lock Key, Removal of circuit component from shift-lock key (optional): 手順 8、 1の画像 1
    • 8. You can remove the circuit component (gray piece attached to the shift lock key spring) by pulling back slightly on its clip and pulling it apart from the shift lock key button.
    • * Take off the shift key button from the spring by using any Philips screwdriver to pry it off from the spring.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Silvanus Clarke
メンバー登録日: 09/26/14
677 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 13-6, Staggers Fall 2014 USF Tampa, Team 13-6, Staggers Fall 2014人のメンバー
USFT-STAGGERS-F14S13G6
4 メンバー
15のガイドは作成済み
1件のガイドコメント
You should desoder the shift lock wires. Not cut them :(
Darek Greenly - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 2,701
