メインコンテンツにスキップ
Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement
必要な工具と部品
  1. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Battery: 手順 1、 2の画像 1 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Battery: 手順 1、 2の画像 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 2、 1の画像 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 3、 2の画像 1 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 3、 2の画像 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 4、 3の画像 1 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 4、 3の画像 2 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 4、 3の画像 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
  5. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Main Power Board: 手順 5、 2の画像 1 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Main Power Board: 手順 5、 2の画像 2
    • Remove the single 1.2 mm Phillips #1 screw on the bottom of the lantern.
    • Remove the plastic barrier.
  6. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 6、 2の画像 1 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 6、 2の画像 2
    • Unscrew the single 1.2 mm Phillips #1 screw holding the motherboard to the plastic lantern housing.
  7. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 7、 3の画像 1 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 7、 3の画像 2 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement: 手順 7、 3の画像 3
    • Gently grab the main board by the exposed PCB.
    • Pull the main board straight out of the housing.
  8. Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Lantern Power Switch: 手順 8、 2の画像 1 Coleman Rechargeable Fluorescent Twin Tube Lantern Power Switch Replacement, Lantern Power Switch: 手順 8、 2の画像 2
    • Remove the switch by pushing down on the ends while simultaneously pulling it out of the slot.
    • When removing the switch, make sure to depress the inner clips when removing from the device. Be careful, do not force the switch from the base of the lantern.
終わりに
作成者
4人の作成者と共同で作成されました。
Mathew Merrick
メンバー登録日: 09/17/18
169 ポイント
2のガイドは作成済み
チーム
Washington State, Team S2-G1, Hope Fall 2018 Washington State, Team S2-G1, Hope Fall 2018人のメンバー
WSU-HOPE-F18S2G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 871
