メインコンテンツにスキップ
Coleman Rechargeable Fluorescent Twin Tube Battery Replacement
必要な工具と部品
  1. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: 手順 1、 2の画像 1 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement, Battery: 手順 1、 2の画像 2
    • Carefully turn the lantern upside down.
    • Remove the three 1.2 mm Phillips #0 screws from the base of the lantern.
  2. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 手順 2、 1の画像 1
    • Carefully pull the bottom of the lantern to remove the base from the device.
  3. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 手順 3、 2の画像 1 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 手順 3、 2の画像 2
    • Gently pull the battery out of the slot and away from the base.
    • The battery may be held into place by adhesive strips.
  4. Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 手順 4、 3の画像 1 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 手順 4、 3の画像 2 Coleman Rechargeable Fluorescent Twin Tube Battery  Replacement: 手順 4、 3の画像 3
    • Carefully detach the negative wire from the battery terminal first.
    • Next, detach the positive wire from the battery terminal.
終わりに
作成者
3人の作成者と共同で作成されました。
Sean
メンバー登録日: 09/17/18
265 ポイント
2のガイドは作成済み
チーム
Washington State, Team S2-G1, Hope Fall 2018 Washington State, Team S2-G1, Hope Fall 2018人のメンバー
WSU-HOPE-F18S2G1
4 メンバー
8のガイドは作成済み
コメント 1 件
Sean, I’m facing a dead battery in my Coleman twin tube fluorescent lantern also. Your directions are spot on except my battery seems to be glued in with super glue! I’ve tried a heat gun and all my strength but my battery won’t come loose. I find it hard to pry under the battery because of the shape of the plastic partitions around the battery. How did you get the battery unstuck?
BilMcKelvy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 93
今までの合計 4,889
