メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
パーツ
パーツは指定されていません。
  1. Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
    • Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
  2. Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
    • Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
  3. iPhone LCDスクリーン修理キット
    生涯保証付きの低コストオプション
    キット商品を見る
    品質ではなく、修理コストを削減しましょう。
    キット商品を見る
  4. Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
    • Note that clicking noises will be heard during this process, the panels are assembled well so it may take some force to separate the two panels.
    • Use caution while prying, do not stick the metal spudger in too far as it may damage internal components
  5. Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
    • Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
  6. Before removing the screen from the cover, dissconnect the large gold ribbon cable by gently sliding the black tab out until it clicks.
    • Before removing the screen from the cover, dissconnect the large gold ribbon cable by gently sliding the black tab out until it clicks.
    • Gently pull the ribbon cable from the port.
  7. Remove the screen from the device.
    • Remove the screen from the device.
終わりに
2 の人々がこのガイドを完成させました。
Ian Swett
メンバー登録日: 2015年03月11日
597 ポイント
5のガイドは作成済み
チーム
Colorado Springs, Team 5-3, Panko Spring 2015 Colorado Springs, Team 5-3, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S5G3
3 メンバー
12のガイドは作成済み
3 件のコメント
Is the flex cable detachable from the LCD
maynell Rodrigues - 返信
Do u have the display flex cable
how much does it cost for screen
jnapps mu - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 877
