メインコンテンツにスキップ
Coby KYROS MID7125 Side Lock Button Replacement
必要な工具と部品
  1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: 手順 1、 1の画像 1
    • Begin by removing back panel using the large opening tool.
  2. Coby KYROS MID7125 Side Lock Button Replacement: 手順 2、 3の画像 1 Coby KYROS MID7125 Side Lock Button Replacement: 手順 2、 3の画像 2 Coby KYROS MID7125 Side Lock Button Replacement: 手順 2、 3の画像 3
    • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
  3. Coby KYROS MID7125 Side Lock Button Replacement: 手順 3、 1の画像 1
    • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
    • Review Battery Replacement for details on how to remove battery.
  4. Coby KYROS MID7125 Side Lock Button Replacement: 手順 4、 2の画像 1 Coby KYROS MID7125 Side Lock Button Replacement: 手順 4、 2の画像 2
    • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
  5. Coby KYROS MID7125 Side Lock Button Replacement: 手順 5、 1の画像 1
    • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
    • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
  6. Coby KYROS MID7125 Side Lock Button Replacement: 手順 6、 1の画像 1
    • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
    • Reverse steps 1-5 to reassemble.
終わりに
作成者
4人の作成者と共同で作成されました。
Benjamin Foley
メンバー登録日: 10/20/16
125 ポイント
1ガイドが承認済み
チーム
UMass Dartmouth, Team 5-2, Martin Fall 2016 UMass Dartmouth, Team 5-2, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S5G2
3 メンバー
10のガイドは作成済み
1件のガイドコメント
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 297
