メインコンテンツにスキップ
Coby DVD209 Circuitboards Replacement
必要な工具と部品
  1. Coby DVD209 Circuitboards Replacement, The bottom portion of the DVD player: 手順 1、 3の画像 1 Coby DVD209 Circuitboards Replacement, The bottom portion of the DVD player: 手順 1、 3の画像 2 Coby DVD209 Circuitboards Replacement, The bottom portion of the DVD player: 手順 1、 3の画像 3
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 Circuitboards Replacement: 手順 2、 3の画像 1 Coby DVD209 Circuitboards Replacement: 手順 2、 3の画像 2 Coby DVD209 Circuitboards Replacement: 手順 2、 3の画像 3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 Circuitboards Replacement: 手順 3、 3の画像 1 Coby DVD209 Circuitboards Replacement: 手順 3、 3の画像 2 Coby DVD209 Circuitboards Replacement: 手順 3、 3の画像 3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 Circuitboards Replacement, 4-Pin Ribbon Cable: 手順 4、 3の画像 1 Coby DVD209 Circuitboards Replacement, 4-Pin Ribbon Cable: 手順 4、 3の画像 2 Coby DVD209 Circuitboards Replacement, 4-Pin Ribbon Cable: 手順 4、 3の画像 3
    • Position the DVD player so that the power and AVI ports are facing you.
    • Pull the white cable with the blue adapters off of the circuit boards.
  5. Coby DVD209 Circuitboards Replacement, Circuitboards: 手順 5、 3の画像 1 Coby DVD209 Circuitboards Replacement, Circuitboards: 手順 5、 3の画像 2 Coby DVD209 Circuitboards Replacement, Circuitboards: 手順 5、 3の画像 3
    • Using the plastic opening tool and your finger, push on the black tab on the inner part of the power port and lift the bottom outer portion of the power port with the plastic opening tool simultaneously.
    • Lift the power port out of the its slot.
  6. Coby DVD209 Circuitboards Replacement: 手順 6、 3の画像 1 Coby DVD209 Circuitboards Replacement: 手順 6、 3の画像 2 Coby DVD209 Circuitboards Replacement: 手順 6、 3の画像 3
    • Remove the four 5mm screws circled in red.
    • Place the blue plastic tool opener underneath the circuitboard and lift up gently.
  7. Coby DVD209 Circuitboards Replacement: 手順 7、 3の画像 1 Coby DVD209 Circuitboards Replacement: 手順 7、 3の画像 2 Coby DVD209 Circuitboards Replacement: 手順 7、 3の画像 3
    • Unplug the two, 3-pin ribbon cables, which are attached to the circuitboard.
    • For the other circuit board (the one connected to the AVI ports) there are three 6.35mm screws to remove on the outside of the device.
  8. Coby DVD209 Circuitboards Replacement: 手順 8、 3の画像 1 Coby DVD209 Circuitboards Replacement: 手順 8、 3の画像 2 Coby DVD209 Circuitboards Replacement: 手順 8、 3の画像 3
    • Place the plastic opening tool underneath the circuit board, and lift up genttly. As you lift up, slide the circuitboard in a direction away from the AVI ports.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Kyle VanAllen
メンバー登録日: 01/20/12
70 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012人のメンバー
CPSU-AMIDO-W12S10G36
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 414
