はじめに
This outer cover is the main cover that protects the inner electrical components. Perform the guide on a flat non-conductive surface to avoid electrical shock and damage to your device.
パーツ
パーツは必要ありません。
  1. Turn the power switch, the leftmost knob, counterclockwise to off. Turn the power switch, the leftmost knob, counterclockwise to off.
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Turn the device around and firmly pull the power cable plug to remove it from the radio. Turn the device around and firmly pull the power cable plug to remove it from the radio.
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
  3. Unscrew the securing cap counterclockwise from the antenna connector. Unscrew the securing cap counterclockwise from the antenna connector.
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Gently pull the antenna cable to remove it from the back of the radio. Gently pull the antenna cable to remove it from the back of the radio.
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  6. Unscrew the cap counterclockwise on the microphone plug to disconnect the cable. Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
  7. Gently unplug the microphone plug.
    • Gently unplug the microphone plug.
  8. Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver. Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  9. Gently life and remove the top cover. Gently life and remove the top cover. Gently life and remove the top cover.
    • Gently life and remove the top cover.
  10. Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio. Carefully flip the radio over. Carefully flip the radio over.
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  11. Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver. Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  12. Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far. Gently lift and remove the case cover. Gently lift and remove the case cover.
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
まとめ
2 の人々がこのガイドを完成させました。
Chase
メンバー登録日: 2013年10月20日
261 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-37, Amido Fall 2013 Cal Poly, Team 11-37, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S11G37
4 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 1,184
