はじめに
The internal speaker is located inside the device and it is attached to the bottom cover. Perform the guide on a flat non-conductive surface to avoid electrical shock and damage to your device.
Some steps in this guide require soldering. For information on how to solder, see the soldering guide.
必要な工具と部品
Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
De-solder the red wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
2 の人々がこのガイドを完成させました。
