メインコンテンツにスキップ
Clothing Ribbon Button Replacement
必要な工具と部品
  1. Clothing Ribbon Button Replacement, Ribbon Button: 手順 1、 2の画像 1 Clothing Ribbon Button Replacement, Ribbon Button: 手順 1、 2の画像 2
    • Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
    • Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
  2. Clothing Ribbon Button Replacement: 手順 2、 2の画像 1 Clothing Ribbon Button Replacement: 手順 2、 2の画像 2
    • Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
    • If you are are using a ribbon that has an obvious front and back, insert the ribbon so that the back is facing out.
  3. Clothing Ribbon Button Replacement: 手順 3、 3の画像 1 Clothing Ribbon Button Replacement: 手順 3、 3の画像 2 Clothing Ribbon Button Replacement: 手順 3、 3の画像 3
    • Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
    • Do not sew the pocket with the ribbon end in it closed.
    • Sew the ribbon in place.
  4. Clothing Ribbon Button Replacement: 手順 4、 3の画像 1 Clothing Ribbon Button Replacement: 手順 4、 3の画像 2 Clothing Ribbon Button Replacement: 手順 4、 3の画像 3
    • Backstitch to hold the stitches in place.
    • Lift the presser foot and remove the garment from the sewing machine.
    • Clip any threads.
  5. Clothing Ribbon Button Replacement: 手順 5、 3の画像 1 Clothing Ribbon Button Replacement: 手順 5、 3の画像 2 Clothing Ribbon Button Replacement: 手順 5、 3の画像 3
    • Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
  6. Clothing Ribbon Button Replacement: 手順 6、 3の画像 1 Clothing Ribbon Button Replacement: 手順 6、 3の画像 2 Clothing Ribbon Button Replacement: 手順 6、 3の画像 3
    • Pull the ribbon taught.
    • The button should be facing with the backside out.
    • Fold the button and ribbon back over, so that the other side of the button is facing out.
    • Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
  7. Clothing Ribbon Button Replacement: 手順 7、 2の画像 1 Clothing Ribbon Button Replacement: 手順 7、 2の画像 2
    • Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
    • Overlap the two ends of the ribbon so that they sit directly on top of one another.
    • Sew directly over the seam, closing the little pocket.
    • This seam should catch both ends of the ribbon between the two layers of the pocket.
  8. Clothing Ribbon Button Replacement: 手順 8、 3の画像 1 Clothing Ribbon Button Replacement: 手順 8、 3の画像 2 Clothing Ribbon Button Replacement: 手順 8、 3の画像 3
    • Backstitch to hold the seam in place.
    • Remove the garment from the sewing machine.
  9. Clothing Ribbon Button Replacement: 手順 9、 2の画像 1 Clothing Ribbon Button Replacement: 手順 9、 2の画像 2
    • Clip any threads.
    • Admire your handiwork.
ゴール
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Brittany McCrigler
メンバー登録日: 03/05/12
89,128 ポイント
131のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,041のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 31
今までの合計 2,893
