メインコンテンツにスキップ
Cloth Face Mask Nose Bridge Replacement
必要な工具と部品
  1. Cloth Face Mask Nose Bridge Replacement, Nose Bridge: 手順 1、 2の画像 1 Cloth Face Mask Nose Bridge Replacement, Nose Bridge: 手順 1、 2の画像 2
    • It's best to wash your mask before and after handling to ensure cleanliness.
    • Lay the mask flat on desired surface.
    • Optional: Steam mask with a clothing iron to completely flatten and remove wrinkles.
    • Caution: Never leave the clothing iron unattended. Use caution when ironing as the machine will be hot to the touch.
    • Measure out the width of your face mask.
  2. Cloth Face Mask Nose Bridge Replacement: 手順 2、 2の画像 1 Cloth Face Mask Nose Bridge Replacement: 手順 2、 2の画像 2
    • Using a pen or pencil, mark the insertion point for the pipe cleaners.
    • A fabric pencil would be better suited for markings as it can be easily washed off.
  3. Cloth Face Mask Nose Bridge Replacement: 手順 3、 1の画像 1
    • Seam rip where the elastic portion is. If there is no elastic present, then seam rip along the top portion of the mask.
    • Caution: Be mindful of where you place your fingers as it is possible to accidentally jab yourself with the seam ripper.
    • Consider using a thimble for protection.
  4. Cloth Face Mask Nose Bridge Replacement: 手順 4、 2の画像 1 Cloth Face Mask Nose Bridge Replacement: 手順 4、 2の画像 2
    • Cut a 4” strip of pipe cleaner.
    • Use caution when cutting pipe cleaners with scissors.
  5. Cloth Face Mask Nose Bridge Replacement: 手順 5、 1の画像 1
    • Position the pipe cleaner where the markings are and fold the fabric over.
    • You may also use this as an opportunity to test out the positioning of the pipe cleaners before sewing the hem.
  6. Cloth Face Mask Nose Bridge Replacement: 手順 6、 1の画像 1
    • Sew around the pipe cleaner using desired stitch.
    • A basic running stitch is recommended for ease.
    • Try on the mask to ensure the fit is right. Bend the pipe cleaners to best suit your facial frame.
ゴール
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Kayla Vargas
メンバー登録日: 02/23/21
157 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S3-G15, Cowan Spring 2021 Texas Tech, Team S3-G15, Cowan Spring 2021人のメンバー
TTU-COWAN-S21S3G15
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 22
今までの合計 591
