メインコンテンツにスキップ
Cleaning/Replacing the Filters of a Split Air Conditioner
必要な工具と部品
  1. Cleaning/Replacing the Filters of a Split Air Conditioner, Filters: 手順 1、 3の画像 1 Cleaning/Replacing the Filters of a Split Air Conditioner, Filters: 手順 1、 3の画像 2 Cleaning/Replacing the Filters of a Split Air Conditioner, Filters: 手順 1、 3の画像 3
    • Turn off the air conditioner using the remote controller.
    • Unplug the A/C unit from its power source.
  2. Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 2、 2の画像 1 Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 2、 2の画像 2
    • Place your hands on the edges of the lid, and pull the lid up to open it.
    • Apply force as needed in a progressive motion. A small tug might be necessary if the lid is very hard to open.
  3. Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 3、 2の画像 1 Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 3、 2の画像 2
    • Grab the filter by the small tab located at the bottom.
    • Pull the filter towards yourself to snap it out of the slot that holds it in place.
    • Pull the whole filter out of the A/C unit.
  4. Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 4、 1の画像 1
    • OPTIONAL STEP: If your filters are broken or damaged – consider buying new filters.
    • Buy filters that are specifically made for your model of the air conditioner. Otherwise, the filters might not fit into the unit or the device may not function properly.
    • Skip steps 5-7 and continue with step 8 after you’ve purchased your new filters.
  5. Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 5、 1の画像 1
    • Wash the filters under streaming water:.
    • Slide the filter from side to side to ensure every part of the filter is washed with the stream.
  6. Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 6、 2の画像 1 Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 6、 2の画像 2
    • OPTIONAL STEP: Follow this step if filters are very dirty and have lots of dust buildup on them.
    • Place your filters in a bucket with one part water and one part vinegar.
    • Leave for one hour to soak.
    • Wash the filters in circular motions with a soapy sponge.
    • Make sure you washed every part of the filter.
    • Rinse the filter thoroughly with water.
  7. Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 7、 1の画像 1
    • Place your filters on a towel in a dry room and let them completely dry out before proceeding to the next step.
    • This might take approximately 20-40 minutes.
  8. Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 8、 2の画像 1 Cleaning/Replacing the Filters of a Split Air Conditioner: 手順 8、 2の画像 2
    • Potential for device damage: Filters must be completely dry before doing this step.
    • Make sure the small tab is located on the bottom of the filter and is facing you.
    • Place the filters back inside, pushing them forward until they click and fall back into place.
終わりに
To reassemble your device, close the lid of the A/C and plug it into power.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Daria Maltseva
メンバー登録日: 01/19/21
265 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G6, Woodhouse Winter 2021 York University, Team S1-G6, Woodhouse Winter 2021人のメンバー
YORK-WOODHOUSE-W21S1G6
1 メンバー
1のガイドは作成済み
2 件のコメント
I have EL that show me on the screen when I try to open my A/C and it doesn't work anymore. How can I repair it ? Please 🙏
Endless-love - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 16
過去 30 日: 65
今までの合計 958
