はじめに
The coffee spout is a part that is rarely cleaned and is not cleaned efficiently by the cleaning program.
This guide will show you how to easily disassemble and manually clean it.
必要な工具と部品
Now slide the spudger/screwdriver between the plastic cap and the cover and gently pry in the direction of the coffee machine. This pushes the cover over the barb.
Grab the cover by the sides and pull it up. This is often very difficult, so pull it hard but not excessively.
Work through the steps in reverse order to reassemble your device.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
