メインコンテンツにスキップ
Classical Guitar Strings Replacement
必要な工具と部品
  1. Classical Guitar Strings Replacement, Strings: 手順 1、 1の画像 1
    • Unwind the string by turning the tuning knob clockwise until the string is slack.
    • Once the string is slack take it out of the tuning peg.
  2. Classical Guitar Strings Replacement: 手順 2、 1の画像 1
    • Push the old string out until it comes out the bridge as shown in the picture.
    • Unwind the knot and pull the old string out of the bridge.
  3. Classical Guitar Strings Replacement: 手順 3、 1の画像 1
    • Put the new string through the bridge leaving about 4-5 inches to be able to tie the knot.
  4. Classical Guitar Strings Replacement: 手順 4、 3の画像 1 Classical Guitar Strings Replacement: 手順 4、 3の画像 2 Classical Guitar Strings Replacement: 手順 4、 3の画像 3
    • To tie the knot, start by wrapping the string back over the bridge and behind itself.
    • Put the end of the string through the opening created above the bridge.
    • While holding the string taut, loop the end through the opening again so it looks like it's wrapped around itself.
    • Two loops is enough for the 3 low strings, but for the 3 higher strings try to get 3 loops to make sure they stay secure.
    • Pull the long end of the string away from the bridge to tighten the knot.
  5. Classical Guitar Strings Replacement: 手順 5、 1の画像 1
    • Put the other end of the new string through the hole in the tuning peg.
  6. Classical Guitar Strings Replacement: 手順 6、 1の画像 1
    • Tighten the new string by turning the knob counter-clockwise.
    • It helps to hold the string tight with your other hand in the groove of the bridge until it is tight enough to stay on its own.
    • Pay attention to the knot on the bridge while tightening the string. If it is not secure, it can come loose. If this happens, it can cause scratches in the guitar.
    • Tune the new strings a bit higher than what they are supposed to be at to stretch it out and help it settle faster.
    • Repeat Steps 1-6 for the remaining five strings.
    • Make an extra loop in the 3 higher strings when tying the knot to the bridge.
  7. Classical Guitar Strings Replacement: 手順 7、 1の画像 1
    • Let the new strings settle for at least a few hours to make sure they are properly secured and the knots all hold.
    • Once they are settled, cut off the excess length of string below the bridge and on the tuners.
終わりに
Congratulations, your guitar now has a shiny new set of strings on it! It should have a much fuller, clearer, and louder sound than it did with the old strings. Now get out there and make some music!
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
James Snyder
メンバー登録日: 07/05/23
172 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 1-7, Meigs Summer 2023 Austin Community College, Team 1-7, Meigs Summer 2023人のメンバー
AUSTINCC-MEIGS-SU23S1G7
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 57
