メインコンテンツにスキップ
はじめに
Taking your clarinet to the music store to get your cork replace can be expensive. Following this guide by removing and replacing the cork yourself can save you a lot of money.
  1. Using pliers, remove the old cork by pinching it off.
    • Using pliers, remove the old cork by pinching it off.
  2. Clean the joint with soap and water
    • Clean the joint with soap and water
  3. Measure the width of the tenon joint.
    • Measure the width of the tenon joint.
    • Only measure the area where the cork will lie, not the entire joint.
  4. Cut the new cork to match the width of the tenon joint.
    • Cut the new cork to match the width of the tenon joint.
  5. Peel off the backside of the cork to reveal the adhesive.
    • Peel off the backside of the cork to reveal the adhesive.
  6. Wrap the cork around the joint.
    • Wrap the cork around the joint.
  7. Sand the cork with sandpaper until the cork is smooth.
    • Sand the cork with sandpaper until the cork is smooth.
  8. Apply cork grease on the new cork.
    • Apply cork grease on the new cork.
  9. Slowly twist and slide the joint back together.
    • Slowly twist and slide the joint back together.
終わりに
Once your clarinet is reassembled, leave the joint together for at least a few hours to let the cork compress and adhere properly. Play the fully assembled clarinet or blow some air through the joint to check for any leaks. When you are ready to put it away, disassemble it carefully. Enjoy your new cork!
5 の人々がこのガイドを完成させました。
Hill Xiong
メンバー登録日: 2017年10月26日
215 ポイント
1ガイドが承認済み
チーム
UC Santa Barbara, Team S3-G1, Weedon Fall 2017 UC Santa Barbara, Team S3-G1, Weedon Fall 2017人のメンバー
UCSB-WEEDON-F17S3G1
3 メンバー
1のガイドは作成済み
3 件のコメント
Where do you buy the corks from? Could you post a link to them?
Joshua Leung - 返信
Make sure to use sandpaper with around 60 - 80 grit
[deleted] - 返信
Wat if the cork strips don't have adhesive.wat do I use
kendall mckenzie - 返信
コメントを追加
統計データを表示:
過去 24時間: 5
過去 7 日: 28
過去 30 日: 109
今までの合計 7,702
