メインコンテンツにスキップ
Citizen Men's Watch 1102 Series Hands Replacement
必要な工具と部品
  1. Citizen Men's Watch 1102 Series Hands Replacement, Watch Face Hands: 手順 1、 1の画像 1
    • Locate the notch under the back cap of the watch. Wedge the jimmy into the notch, and pry off the back.
  2. Citizen Men's Watch 1102 Series Hands Replacement: 手順 2、 1の画像 1
    • Remove the circular plastic cover from inside the watch.
  3. Citizen Men's Watch 1102 Series Hands Replacement: 手順 3、 1の画像 1
    • Remove the crown stalk by placing the needle in the release notch. This will release stalk and allow it to slide out.
  4. Citizen Men's Watch 1102 Series Hands Replacement: 手順 4、 1の画像 1
    • Turn watch on its side and let the watch face fall out.
  5. Citizen Men's Watch 1102 Series Hands Replacement: 手順 5、 1の画像 1
    • Gently pry the watch hands off of the face of the watch with the jimmy and tweezers.
  6. Citizen Men's Watch 1102 Series Hands Replacement: 手順 6、 1の画像 1
    • Use the tweezers to replace the hands of the watch.
    • First, place the hour hand on the watch face stem, followed by the minute hand, and the second hand.
  7. Citizen Men's Watch 1102 Series Hands Replacement: 手順 7、 1の画像 1
    • Place the watch face downwards in its case.
    • Make sure the crown stalk holes are aligned.
  8. Citizen Men's Watch 1102 Series Hands Replacement: 手順 8、 1の画像 1
    • Insert the crown stalk into the crown stalk holes.
  9. Citizen Men's Watch 1102 Series Hands Replacement: 手順 9、 1の画像 1
    • Place the plastic cover back in its original place.
    • Use the crown notch for guidance in alignment.
  10. Citizen Men's Watch 1102 Series Hands Replacement: 手順 10、 1の画像 1
    • Press the back cover on the watch using hands or clamp, until it pops into place.
終わりに
Now that the watch hands are repaired, the watch can be reset manually so that the it can keep the correct time.
作成者
1人の作成者と共同作成されました。
Justin Sidwell
メンバー登録日: 02/28/17
111 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S4-G5, Baddour Spring 2017 University of Memphis, Team S4-G5, Baddour Spring 2017人のメンバー
UM-BADDOUR-S17S4G5
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 25
今までの合計 3,523
