メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Cisco 878 Router StrataFlash Memory module Replacement/Upgrade
必要な工具と部品
  1. Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the two screws on back side: 手順 1、 3の画像 1 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the two screws on back side: 手順 1、 3の画像 2 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the two screws on back side: 手順 1、 3の画像 3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove top cover: 手順 2、 3の画像 1 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove top cover: 手順 2、 3の画像 2 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove top cover: 手順 2、 3の画像 3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the three screws on front side: 手順 3、 2の画像 1 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the three screws on front side: 手順 3、 2の画像 2
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the inner metal shield: 手順 4、 3の画像 1 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the inner metal shield: 手順 4、 3の画像 2 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove the inner metal shield: 手順 4、 3の画像 3
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
  5. Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove  StrataFlash Memory module: 手順 5、 3の画像 1 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove  StrataFlash Memory module: 手順 5、 3の画像 2 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Remove  StrataFlash Memory module: 手順 5、 3の画像 3
    • 1. Place your fingers on the levers at the two sides of the slot, and push open.
    • 2. Firmly pull the release lever away from the module until the module pops up.
    • 3. You can then remove the module from the module slot.
  6. Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Installing new module: 手順 6、 2の画像 1 Cisco 878 Router StrataFlash Memory module Replacement/Upgrade, Installing new module: 手順 6、 2の画像 2
    • 1. Insert the notched edge of the module into the slot at an angle.
    • 2. Firmly press down the unnotched edge of the module until you hear a click. The indents must be fully in the notches.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jiri Altman
メンバー登録日: 05/03/16
1,563 ポイント
9のガイドは作成済み
チーム
4k20 Repair Team 4k20 Repair Team人のメンバー
Community
2 メンバー
17のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 494
