メインコンテンツにスキップ
Cisco 878 Integrated Services Router Inner Metal Shield Disassembly
必要な工具と部品
  1. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the two screws on back side: 手順 1、 3の画像 1 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the two screws on back side: 手順 1、 3の画像 2 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the two screws on back side: 手順 1、 3の画像 3
    • Only trained and qualified personnel should be allowed to install, replace, or service this equipment!
    • During this procedure, wear grounding wrist straps to avoid ESD damage to the card. Do not directly touch the backplane with your hand or any metal tool, or you could shock yourself!
    • Make sure that the power switch is turned to standby and that the power supply cable is disconnected. Disconnect all cables from the router back panel.
    • Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
  2. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove top cover: 手順 2、 3の画像 1 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove top cover: 手順 2、 3の画像 2 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove top cover: 手順 2、 3の画像 3
    • 1. Gently push the top cover of the router away from you.
    • 2. Lift it up top cover from the bottom of the router.
    • 3. Remove top cover from the device.
    • Place the router bottom on an antistatic mat.
  3. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the three screws on front side: 手順 3、 2の画像 1 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the three screws on front side: 手順 3、 2の画像 2
    • Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
  4. Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the inner metal shield: 手順 4、 3の画像 1 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the inner metal shield: 手順 4、 3の画像 2 Cisco 878 Integrated Services Router Inner Metal Shield Disassembly, Remove the inner metal shield: 手順 4、 3の画像 3
    • 1. Gently lift up inner metal shield from the bottom of the router.
    • 2. Remove inner metal shield from the device (see the anchors on the picture).
    • Be careful and do not distort the plates!
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Jiri Altman
メンバー登録日: 05/03/16
1,521 ポイント
9のガイドは作成済み
チーム
4k20 Repair Team 4k20 Repair Team人のメンバー
Community
2 メンバー
17のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 13
今までの合計 212
