メインコンテンツにスキップ
Cineyo BT-03 Device Page Button Replacement
必要な工具と部品
  1. Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 1 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 2 Cineyo BT-03 Device Page Button Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Page Button Replacement: 手順 2、 2の画像 1 Cineyo BT-03 Device Page Button Replacement: 手順 2、 2の画像 2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Page Button Replacement: 手順 3、 3の画像 1 Cineyo BT-03 Device Page Button Replacement: 手順 3、 3の画像 2 Cineyo BT-03 Device Page Button Replacement: 手順 3、 3の画像 3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Page Button Replacement: 手順 4、 3の画像 1 Cineyo BT-03 Device Page Button Replacement: 手順 4、 3の画像 2 Cineyo BT-03 Device Page Button Replacement: 手順 4、 3の画像 3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Page Button Replacement: 手順 5、 1の画像 1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Page Button Replacement: 手順 6、 1の画像 1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Page Button Replacement, Button: 手順 7、 2の画像 1 Cineyo BT-03 Device Page Button Replacement, Button: 手順 7、 2の画像 2
    • With a Phillips #1 screwdriver, remove the two 5mm screws which attach the button mount to the plastic casing of the device.
  8. Cineyo BT-03 Device Page Button Replacement: 手順 8、 2の画像 1 Cineyo BT-03 Device Page Button Replacement: 手順 8、 2の画像 2
    • Using a plastic opening tool, pry the button mount off of the plastic casing of the device.
  9. Cineyo BT-03 Device Page Button Replacement: 手順 9、 2の画像 1 Cineyo BT-03 Device Page Button Replacement: 手順 9、 2の画像 2
    • Using a soldering iron and iFixit’s Soldering Guide, remove the individual buttons.
終わりに
作成者
3人の作成者と共同で作成されました。
Rene Klopf
メンバー登録日: 01/30/17
463 ポイント
4のガイドは作成済み
チーム
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017人のメンバー
BU-WHITNEY-S17S8G3
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 86
