メインコンテンツにスキップ
Cineyo BT-03 Device Battery Replacement
必要な工具と部品
  1. Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 1 Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 2 Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: 手順 1、 3の画像 3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Battery Replacement: 手順 2、 2の画像 1 Cineyo BT-03 Device Battery Replacement: 手順 2、 2の画像 2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Battery Replacement: 手順 3、 3の画像 1 Cineyo BT-03 Device Battery Replacement: 手順 3、 3の画像 2 Cineyo BT-03 Device Battery Replacement: 手順 3、 3の画像 3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Battery Replacement: 手順 4、 3の画像 1 Cineyo BT-03 Device Battery Replacement: 手順 4、 3の画像 2 Cineyo BT-03 Device Battery Replacement: 手順 4、 3の画像 3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Battery Replacement: 手順 5、 1の画像 1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Battery Replacement: 手順 6、 1の画像 1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Battery Replacement, Battery: 手順 7、 2の画像 1 Cineyo BT-03 Device Battery Replacement, Battery: 手順 7、 2の画像 2
    • Pull the wires connecting the blue battery out of the circuit board.
  8. Cineyo BT-03 Device Battery Replacement: 手順 8、 2の画像 1 Cineyo BT-03 Device Battery Replacement: 手順 8、 2の画像 2
    • Using your fingers, pull the blue battery out of the casing.
    • There might be slight hesitation due to the adhesive attaching the battery to the casing, so a slight bit of force might be necessary.
終わりに
作成者
4人の作成者と共同で作成されました。
Cole Crawford
メンバー登録日: 02/13/17
85 ポイント
1ガイドが承認済み
チーム
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017人のメンバー
BU-WHITNEY-S17S8G3
5 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 175
