メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Chromecast Metal Shielding Replacement
必要な工具と部品
  1. Chromecast Metal Shielding Replacement, Case: 手順 1、 1の画像 1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Metal Shielding Replacement: 手順 2、 1の画像 1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Metal Shielding Replacement: 手順 3、 1の画像 1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Metal Shielding Replacement: 手順 4、 1の画像 1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Metal Shielding Replacement: 手順 5、 2の画像 1 Chromecast Metal Shielding Replacement: 手順 5、 2の画像 2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Metal Shielding Replacement, Metal Shielding: 手順 6、 1の画像 1
    • Pry the metal extensions from the HDMI port.
  7. Chromecast Metal Shielding Replacement: 手順 7、 1の画像 1
    • Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
  8. Chromecast Metal Shielding Replacement: 手順 8、 1の画像 1
    • Pry the metal piece around the metal, extruding it from the internal components.
  9. Chromecast Metal Shielding Replacement: 手順 9、 1の画像 1
    • Completely remove the top metal casing to expose the internal components.
  10. Chromecast Metal Shielding Replacement: 手順 10、 1の画像 1
    • Pry metal extensions from the HDMI port on the posterior side of the device.
  11. Chromecast Metal Shielding Replacement: 手順 11、 1の画像 1
    • Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
  12. Chromecast Metal Shielding Replacement: 手順 12、 1の画像 1
    • Continue prying around the device, removing the metal piece from the internal components.
  13. Chromecast Metal Shielding Replacement: 手順 13、 1の画像 1
    • Completely remove the bottom metal piece.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Cameron Heiges
メンバー登録日: 03/21/18
688 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S5-G6, Baechle Spring 2018 IUPUI, Team S5-G6, Baechle Spring 2018人のメンバー
IUPUI-BAECHLE-S18S5G6
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 28
今までの合計 1,798
